Ana içeriğe geç
Compaq Presario CQ60-211DX Solid State Drive Replacement
Neye ihtiyacın var
  1. Compaq Presario CQ60-211DX Solid State Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop off and disconnect all sources of power.
    • Set the laptop on a flat surface with the bottom side facing up.
  2. Compaq Presario CQ60-211DX Solid State Drive Replacement: adım 2, 3 resimden 1. Compaq Presario CQ60-211DX Solid State Drive Replacement: adım 2, 3 resimden 2. Compaq Presario CQ60-211DX Solid State Drive Replacement: adım 2, 3 resimden 3.
    • Slide the battery release tab.
    • This will eject the battery.
    • Carefully remove the battery and set it aside.
  3. Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): adım 3, 2 resimden 1. Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): adım 3, 2 resimden 2.
    • Use a PH1 screwdriver to unscrew the 2 screws that secure the hard drive cover.
    • Remove the cover.
  4. Compaq Presario CQ60-211DX Solid State Drive Replacement: adım 4, 2 resimden 1. Compaq Presario CQ60-211DX Solid State Drive Replacement: adım 4, 2 resimden 2.
    • Unscrew the next three screws holding the hard drive in place.
    • Pull the black ribbon and slide the hard drive out of place.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,038
