Ana içeriğe geç
Compaq Presario CQ62-215dx CPU Replacement
Neye ihtiyacın var
  1. Compaq Presario CQ62-215dx CPU Replacement, CPU: adım 1, 1 resimden 1.
    • Turn the laptop upside down.
    • Remove all the 3.0mm Phillips #00 screws from the back cover.
  2. Compaq Presario CQ62-215dx CPU Replacement: adım 2, 1 resimden 1.
    • Remove the battery, RAM, and hard drive.
  3. Compaq Presario CQ62-215dx CPU Replacement: adım 3, 1 resimden 1.
    • Remove four 1.2mm Phillips #00 screws under the battery.
  4. Compaq Presario CQ62-215dx CPU Replacement: adım 4, 1 resimden 1.
    • Turn the laptop over, and open the laptop cover.
    • Use a spudger or your hand to carefully remove the keyboard.
  5. Compaq Presario CQ62-215dx CPU Replacement: adım 5, 1 resimden 1.
    • Use a spudger or your hand to lift the outside frame from the corner of the laptop.
  6. Compaq Presario CQ62-215dx CPU Replacement: adım 6, 1 resimden 1.
    • Remove all the 1.2mm Phillips #00 screws from the motherboard and in the top corner that secures the fan.
  7. Compaq Presario CQ62-215dx CPU Replacement: adım 7, 1 resimden 1.
    • Unplug the wires connected to the motherboard with a spudger.
  8. Compaq Presario CQ62-215dx CPU Replacement: adım 8, 1 resimden 1.
    • Remove the two 3mm Phillips #00 screws beside the fan.
  9. Compaq Presario CQ62-215dx CPU Replacement: adım 9, 1 resimden 1.
    • Lift the motherboard out carefully.
  10. Compaq Presario CQ62-215dx CPU Replacement: adım 10, 1 resimden 1.
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
  11. Compaq Presario CQ62-215dx CPU Replacement: adım 11, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the three 2mm screws that connect the fan to the CPU.
  12. Compaq Presario CQ62-215dx CPU Replacement: adım 12, 1 resimden 1.
    • Remove the fan from the motherboard.
    • When reassembling, you will need to solder the fan back on to the CPU.
  13. Compaq Presario CQ62-215dx CPU Replacement: adım 13, 1 resimden 1.
    • Use the metal spudger to twist the lock tab on the component.
  14. Compaq Presario CQ62-215dx CPU Replacement: adım 14, 1 resimden 1.
    • Remove current CPU and replace with new component.
Sonuç
Breana Thibodeaux
760 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019 üyesi
UMASSD-VALLIERE-S19S4G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 1,262
