Ana içeriğe geç
Compaq Presario CQ62-215dx Fan Replacement
Neye ihtiyacın var
  1. Compaq Presario CQ62-215dx Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Turn the laptop upside down, and unscrew all the 3.0mm screws on the back cover with a Phillips screwdriver.
  2. Compaq Presario CQ62-215dx Fan Replacement: adım 2, 1 resimden 1.
    • Take out the Battery and the placeholder for the RAM and the Hard Drive
  3. Compaq Presario CQ62-215dx Fan Replacement: adım 3, 1 resimden 1.
    • There are four 1.2mm screws under the battery that are needed to be removed with a Phillips screwdriver.
  4. Compaq Presario CQ62-215dx Fan Replacement: adım 4, 1 resimden 1.
    • Turn the laptop back, and open the laptop cover. Use a spudger or your hand to carefully remove the keyboard.
  5. Compaq Presario CQ62-215dx Fan Replacement: adım 5, 1 resimden 1.
    • Once the keyboard is out, use the Metal Spudger or your hand in the corner of the laptop to lift the outside frame.
  6. Compaq Presario CQ62-215dx Fan Replacement: adım 6, 1 resimden 1.
    • You will have a bigger view of the entire motherboard and there should be screws that are still connected on it.
    • Unscrew all the 1.2mm screws on the motherboard and in the top corner that secures the fan with a Phillips screwdriver.
  7. Compaq Presario CQ62-215dx Fan Replacement: adım 7, 1 resimden 1.
    • Unplug the wires connected to the mother board with the Metal Spudger
  8. Compaq Presario CQ62-215dx Fan Replacement: adım 8, 1 resimden 1.
    • Unscrew the two 3mm screws beside the fan with a Phillips screwdriver.
  9. Compaq Presario CQ62-215dx Fan Replacement: adım 9, 1 resimden 1.
    • If all the screws have been removed, you should be able to lift the motherboard out carefully.
  10. Compaq Presario CQ62-215dx Fan Replacement: adım 10, 1 resimden 1.
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
  11. Compaq Presario CQ62-215dx Fan Replacement: adım 11, 1 resimden 1.
    • Use the Phillips screwdriver to unscrew the three 2mm screws that connect the fan to the CPU.
  12. Compaq Presario CQ62-215dx Fan Replacement: adım 12, 1 resimden 1.
    • Remove the current fan from the motherboard and replace with new component.
    • When reassembling, you will need to reapply thermal paste on the CPU.
Sonuç
Breana Thibodeaux
760 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019 üyesi
UMASSD-VALLIERE-S19S4G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 560
