Ana içeriğe geç
Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement
Neye ihtiyacın var
  1. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement, Hard Drive: adım 1, 1 resimden 1.
    • First you will need to turn the laptop upside down.
  2. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pushing the switch to the left and removing the battery from its slot.
  3. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: adım 3, 1 resimden 1.
    • Unscrew the three 3mm screws on the compartment underneath the battery.
  4. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: adım 4, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 3mm screws on the lowest compartment.
  5. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: adım 5, 1 resimden 1.
    • Use a Metal Spudger remove the panel. Underneath is where the hard drive is connected .
  6. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: adım 6, 1 resimden 1.
    • This is where you detach your old hard drive and replace with the new component.
Sonuç
Breana Thibodeaux
760 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019 üyesi
UMASSD-VALLIERE-S19S4G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 348
