Ana içeriğe geç
Compaq Presario CQ62-215dx RAM Replacement
Neye ihtiyacın var
    1. Compaq Presario CQ62-215dx RAM Replacement, RAM: adım 1, 1 resimden 1.
      • lay the laptop upside down.
      FixBot'a Sor
      Yorum Ekle
    2. Compaq Presario CQ62-215dx RAM Replacement: adım 2, 1 resimden 1.
      • Remove the battery by pushing the lock to the left and lifting the battery from its socket.
      FixBot'a Sor
      Yorum Ekle
    3. Compaq Presario CQ62-215dx RAM Replacement: adım 3, 1 resimden 1.
      • Once the battery is out, locate a panel that is underneath the battery compartment and unscrew the three 3mm screws with a Philips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Compaq Presario CQ62-215dx RAM Replacement: adım 4, 1 resimden 1.
      • Once removed, you should have something like in this picture. Locate the current RAM.
      FixBot'a Sor
      Yorum Ekle
    5. Compaq Presario CQ62-215dx RAM Replacement: adım 5, 1 resimden 1.
      • To remove the RAM, start by lifting up the first card. Grab each side of the card with two fingers as shown in the picture and pull gently until it is removed from its slot.
      FixBot'a Sor
      Yorum Ekle
    6. Compaq Presario CQ62-215dx RAM Replacement: adım 6, 1 resimden 1.
      • Insert your new RAM replacement into the slot where the old one was removed. Push until you hear a small click.
      FixBot'a Sor
      Yorum Ekle
    7. Compaq Presario CQ62-215dx RAM Replacement: adım 7, 1 resimden 1.
      • Push the card downward into the compartment until you hear another clicking sound.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Breana Thibodeaux
760 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019 üyesi
UMASSD-VALLIERE-S19S4G1
3 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 962
