Ana içeriğe geç
Compaq Presario V2414NR Optical Drive Replacement
Neye ihtiyacın var
  1. Compaq Presario V2414NR Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR Optical Drive Replacement: adım 2, 2 resimden 1. Compaq Presario V2414NR Optical Drive Replacement: adım 2, 2 resimden 2.
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR Optical Drive Replacement, Optical Drive: adım 3, 2 resimden 1. Compaq Presario V2414NR Optical Drive Replacement, Optical Drive: adım 3, 2 resimden 2.
    • On the optical drive there is small pin hole. Insert a paperclip or similarly sized object in the hole.
    • The Drive will pop a short way out of the computer.
  4. Compaq Presario V2414NR Optical Drive Replacement: adım 4, 3 resimden 1. Compaq Presario V2414NR Optical Drive Replacement: adım 4, 3 resimden 2. Compaq Presario V2414NR Optical Drive Replacement: adım 4, 3 resimden 3.
    • Remove the 7mm Phillips #1 screw that secures the optical drive to the computer.
    • Grip the sides of the Optical Drive and slide it out until it is completely removed from the computer.
    • When reassembling, slide the optical drive straight in until it clicks.
Sonuç
Rylie Schmidt
765 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 UMass Dartmouth, Team 2-1, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G1
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 205
