Ana içeriğe geç
Compaq Presario V2414NR RAM Replacement
Neye ihtiyacın var
  1. Compaq Presario V2414NR RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR RAM Replacement: adım 2, 2 resimden 1. Compaq Presario V2414NR RAM Replacement: adım 2, 2 resimden 2.
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR RAM Replacement, RAM Cover: adım 3, 2 resimden 1. Compaq Presario V2414NR RAM Replacement, RAM Cover: adım 3, 2 resimden 2.
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR RAM Replacement, RAM: adım 4, 2 resimden 1. Compaq Presario V2414NR RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Use your fingers, or plastic opening tools, to spread the metal retaining tabs on each side of the RAM outwards until the module pops up.
    • Pull the module out of the socket at the same angle it is now oriented.
    • Repeat these steps to remove the second memory module.
    • When reassembling, align the offset notch on the RAM contacts with the tab on the socket and insert at a 30 degree angle.
Sonuç
Rylie Schmidt
765 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 UMass Dartmouth, Team 2-1, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G1
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 262
