Ana içeriğe geç
Compaq Presario v2000 Hard drive Replacement
Neye ihtiyacın var
  1. Compaq Presario v2000 Hard drive Replacement, Hard drive: adım 1, 1 resimden 1.
    • Remove the battery before starting
  2. Compaq Presario v2000 Hard drive Replacement: adım 2, 2 resimden 1. Compaq Presario v2000 Hard drive Replacement: adım 2, 2 resimden 2.
    • Loosen the two screw for the hard drive cover
    • The screws will stay attached the the cover
    • Lift the cover from the left side and remove
  3. Compaq Presario v2000 Hard drive Replacement: adım 3, 2 resimden 1. Compaq Presario v2000 Hard drive Replacement: adım 3, 2 resimden 2.
    • Lift the black pull tab on the hard drive
    • Lift the drive straight up out of the laptop
  4. Compaq Presario v2000 Hard drive Replacement: adım 4, 2 resimden 1. Compaq Presario v2000 Hard drive Replacement: adım 4, 2 resimden 2.
    • Remove the four screws on the sides of the drive (two on each side)
    • Remove the hard drive from the caddy
  5. Compaq Presario v2000 Hard drive Replacement: adım 5, 1 resimden 1.
    • Pull the IDE connecter straight off the drive
    • Be sure to pull the connecter off straight so as not to bend the hard drive IDE pins
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Andrew
1.341 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
Perfect instructions....easy directions even for a computer dunce like me...
John Platania - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 38
Her zaman: 10,345
