Ana içeriğe geç
Compaq Presario v2000 RAM Replacement
Neye ihtiyacın var
    1. Compaq Presario v2000 RAM Replacement, Removing the RAM cover: adım 1, 2 resimden 1. Compaq Presario v2000 RAM Replacement, Removing the RAM cover: adım 1, 2 resimden 2.
      • Loosen the 2 Phillips screws with RAM icons above them. Don’t worry if the screws won’t come out, as they’re attached to the door.
      • Lift the RAM door up and away.
      FixBot'a Sor
      Yorum Ekle
    2. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: adım 2, 3 resimden 1. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: adım 2, 3 resimden 2. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: adım 2, 3 resimden 3.
      • There are two metal clips holding both RAM modules in place.
      • To unclip them, push them both outwards from the RAM stick with your fingers until it pops out and sticks up at an angle.
      • Pull the stick of RAM out.
      • Repeat the last 3 steps for the bottom RAM stick.
      FixBot'a Sor
      Yorum Ekle
    3. Compaq Presario v2000 RAM Replacement, Installing the new RAM: adım 3, 2 resimden 1. Compaq Presario v2000 RAM Replacement, Installing the new RAM: adım 3, 2 resimden 2.
      • Start at the bottom slot. Insert the new RAM at the same angle the previous RAM popped out at.
      • Push the RAM in until a click is heard.
      • Repeat the last 2 steps for the top slot.
      FixBot'a Sor
      Yorum Ekle
    4. Compaq Presario v2000 RAM Replacement, Reinstalling the RAM cover: adım 4, 1 resimden 1.
      • Repeat the first part of this guide to reinstall the RAM door.
      FixBot'a Sor
      Yorum Ekle
Sonuç
If you encounter problems after installing new RAM, redo this guide, or follow a RAM troubleshooting guide.
Viscous
403 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 478
