Ana içeriğe geç
Compaq iPAQ Pocket PC 3830 Motherboard Replacement
Neye ihtiyacın var
  1. Compaq iPAQ Pocket PC 3830 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Compaq iPAQ Pocket PC 3830 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Remove the four 0.8mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the two screws on top of the motherboard and the two screws on bottom of motherboard
  3. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: adım 3, 2 resimden 1. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: adım 3, 2 resimden 2.
    • Detach the wires from their combs on the motherboard.
  4. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: adım 4, 1 resimden 1.
    • Detach from comb that is located on motherboard.
  5. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: adım 5, 2 resimden 1. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the small piece from the motherboard.
  6. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove last piece from the comb on the motherboard.
  7. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the motherboard by simply lifting it.
Sonuç
Sedina Cavcic
464 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 520
