Ana içeriğe geç
Compression Test
Neye ihtiyacın var
  1. Compression Test, Safety precautions: adım 1, 2 resimden 1. Compression Test, Safety precautions: adım 1, 2 resimden 2.
    • Flip the power switch into the STOP position.
    • Make sure the engine is cool to the touch before proceeding.
  2. Compression Test, Remove the spark plug cap: adım 2, 2 resimden 1. Compression Test, Remove the spark plug cap: adım 2, 2 resimden 2.
    • Pull the spark plug cap straight off of the spark plug.
  3. Compression Test, Remove the spark plug: adım 3, 1 resimden 1.
    • Use a 5/8-inch spark plug socket to remove the spark plug from the engine.
  4. Compression Test, Check the spark plug for wear: adım 4, 1 resimden 1.
    • Check if the spark plug is fouled and replace it if necessary.
    • The spark plug pictured in this step is in new condition.
  5. Compression Test, Connect a compression tester: adım 5, 1 resimden 1.
    • Follow the instruction provided with your compression test kit to connect a compression tester to the cylinder.
  6. Compression Test, Test compression: adım 6, 2 resimden 1. Compression Test, Test compression: adım 6, 2 resimden 2.
    • Pull the starter 5–10 times to build pressure in the combustion chamber.
  7. Compression Test: adım 7, 1 resimden 1.
    • Read the compression gauge.
    • Pressure should read 125–165 psi (8.6–11.4 bar).
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
84.862 İtibar
290 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 646
