Ana içeriğe geç
Computer King Muffin Kinder 7 Screen Replacement
Neye ihtiyacın var
  1. Computer King Muffin Kinder 7 Screen Replacement, Screen: adım 1, 2 resimden 1. Computer King Muffin Kinder 7 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Screen Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Screen Replacement: adım 3, 2 resimden 1. Computer King Muffin Kinder 7 Screen Replacement: adım 3, 2 resimden 2.
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Screen Replacement: adım 4, 1 resimden 1.
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Screen Replacement: adım 5, 2 resimden 1. Computer King Muffin Kinder 7 Screen Replacement: adım 5, 2 resimden 2.
    • There will be a black strip connected to the screen.
    • Use the pointy end of the spudger to unstick the black strip that is glued onto the screen.
  6. Computer King Muffin Kinder 7 Screen Replacement: adım 6, 3 resimden 1. Computer King Muffin Kinder 7 Screen Replacement: adım 6, 3 resimden 2. Computer King Muffin Kinder 7 Screen Replacement: adım 6, 3 resimden 3.
    • You will need to remove 2 ribbon cables, one that is connected to the touch screen (by the battery) and one that is connected to the yellow plastic (by the speaker).
    • Use the flat end of the spudger to lift the black panel covering the ribbon cables.
  7. Computer King Muffin Kinder 7 Screen Replacement: adım 7, 1 resimden 1.
    • Pull the two ribbon cables out so that they are no longer connected to the logic board.
  8. Computer King Muffin Kinder 7 Screen Replacement: adım 8, 1 resimden 1.
    • Lift up the logic board and black plastic so that they are no longer covering the screen
    • Lift out the screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Katherine
439 İtibar
3 adet Kılavuz yazıldı
Ekip
UWT Liner: Group 2 UWT Liner: Group 2 üyesi
Community
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 540
