Giriş
If when you hold down the cool down button and the air is still hot, the spring behind the button may be broken. Another possibility is that the other parts of the button inside the dryer that engage that setting may be broken.
Neye ihtiyacın var
Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
Take out the cool down button and the spring behind it by gently lifting the button up toward you and pushing it to the right out of its groove.
Bir başkası bu kılavuzu tamamladı.
