Ana içeriğe geç
Conair Infiniti PRO Curling Iron Heating Element Replacement
Neye ihtiyacın var
  1. Conair Infiniti PRO Curling Iron Heating Element Replacement, Housing: adım 1, 1 resimden 1.
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Heating Element Replacement: adım 2, 1 resimden 1.
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Heating Element Replacement: adım 3, 3 resimden 1. Conair Infiniti PRO Curling Iron Heating Element Replacement: adım 3, 3 resimden 2. Conair Infiniti PRO Curling Iron Heating Element Replacement: adım 3, 3 resimden 3.
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Heating Element Replacement, Power Cord: adım 4, 1 resimden 1.
    • Pull power chord out.
  5. Conair Infiniti PRO Curling Iron Heating Element Replacement, Motherboard: adım 5, 1 resimden 1.
    • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
    • Note the location of wire attachment.
  6. Conair Infiniti PRO Curling Iron Heating Element Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    Satın Al
    • With your soldering gun, desolder the white wire from the motherboard as shown.
  7. Conair Infiniti PRO Curling Iron Heating Element Replacement: adım 7, 1 resimden 1.
    • Once both wires are desoldered the motherboard can be removed.
  8. Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: adım 8, 2 resimden 1. Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: adım 8, 2 resimden 2.
    • Remove the heating element mount. This will free up the heating element barrel for replacement.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jonathon Bruer
607 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S7-G5, Baechle Fall 2017 IUPUI, Team S7-G5, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S7G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 1,525
