Ana içeriğe geç
Conair Infiniti PRO Curling Iron Motherboard Replacement
Neye ihtiyacın var
  1. Conair Infiniti PRO Curling Iron Motherboard Replacement, Housing: adım 1, 1 resimden 1.
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Motherboard Replacement: adım 3, 3 resimden 1. Conair Infiniti PRO Curling Iron Motherboard Replacement: adım 3, 3 resimden 2. Conair Infiniti PRO Curling Iron Motherboard Replacement: adım 3, 3 resimden 3.
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Motherboard Replacement, Power Cord: adım 4, 1 resimden 1.
    • Pull power chord out.
  5. Conair Infiniti PRO Curling Iron Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
    • Note the location of wire attachment.
  6. Conair Infiniti PRO Curling Iron Motherboard Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    Satın Al
    • With your soldering gun, desolder the white wire from the motherboard as shown.
  7. Conair Infiniti PRO Curling Iron Motherboard Replacement: adım 7, 1 resimden 1.
    • Once both wires are desoldered the motherboard can be removed.
Sonuç
To reassemble your device, follow these instructions in reverse order, making sure to resolder the wires correctly into the replacement motherboard.
2 farklı kişi bu kılavuzu tamamladı.
Jonathon Bruer
607 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S7-G5, Baechle Fall 2017 IUPUI, Team S7-G5, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S7G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 572
