Ana içeriğe geç
Conair Infiniti Pro Model 259NP Back Panel Replacement
Neye ihtiyacın var
  1. Conair Infiniti Pro Model 259NP Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Back Panel Replacement: adım 2, 2 resimden 1. Conair Infiniti Pro Model 259NP Back Panel Replacement: adım 2, 2 resimden 2.
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Back Panel Replacement: adım 3, 3 resimden 1. Conair Infiniti Pro Model 259NP Back Panel Replacement: adım 3, 3 resimden 2. Conair Infiniti Pro Model 259NP Back Panel Replacement: adım 3, 3 resimden 3.
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Timothy Lo
1.172 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G58
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 6,387
