Ana içeriğe geç
Conair Infiniti Pro Model 259NP Heat Shield Replacement
Neye ihtiyacın var
  1. Conair Infiniti Pro Model 259NP Heat Shield Replacement, Back Panel: adım 1, 1 resimden 1.
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 2, 2 resimden 1. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 2, 2 resimden 2.
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 3, 3 resimden 1. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 3, 3 resimden 2. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 3, 3 resimden 3.
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Heat Shield Replacement, Fan Motor Assembly: adım 4, 2 resimden 1. Conair Infiniti Pro Model 259NP Heat Shield Replacement, Fan Motor Assembly: adım 4, 2 resimden 2.
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 5, 3 resimden 1. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 5, 3 resimden 2. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 5, 3 resimden 3.
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP Heat Shield Replacement, Heat Shield: adım 6, 3 resimden 1. Conair Infiniti Pro Model 259NP Heat Shield Replacement, Heat Shield: adım 6, 3 resimden 2. Conair Infiniti Pro Model 259NP Heat Shield Replacement, Heat Shield: adım 6, 3 resimden 3.
    • If you recently used the hair dryer, the heating element may still be hot! Do not attempt this guide, you may severely burn yourself.
    • Hold the heating element with the wider end facing upward.
    • Gently pull the heating element out of the heat shield.
  7. Conair Infiniti Pro Model 259NP Heat Shield Replacement: adım 7, 1 resimden 1.
    • Gently pull the heat shield out of its sheath.
Sonuç
Timothy Lo
1.172 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G58
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,680
