Ana içeriğe geç
Connect Four Electronic Handheld Back Casing Replacement
Neye ihtiyacın var
  1. Connect Four Electronic Handheld Back Casing Replacement, Ensure the device is off.: adım 1, 1 resimden 1.
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: adım 2, 2 resimden 1. Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: adım 2, 2 resimden 2.
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: adım 3, 2 resimden 1. Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: adım 3, 2 resimden 2.
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
Sonuç
Wil
313 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G11
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 145
