Ana içeriğe geç
Connect Four Electronic Handheld Battery Replacement
Neye ihtiyacın var
  1. Connect Four Electronic Handheld Battery Replacement, Ensure the device is off.: adım 1, 1 resimden 1.
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
    FixBot'a Sor
    Yorum Ekle
  2. Connect Four Electronic Handheld Battery Replacement, Removing the battery casing.: adım 2, 2 resimden 1. Connect Four Electronic Handheld Battery Replacement, Removing the battery casing.: adım 2, 2 resimden 2.
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Connect Four Electronic Handheld Battery Replacement, Replacing the battery.: adım 3, 1 resimden 1.
    • Put in the new AA battery, ensuring that the negative end slides into the spring.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kamaryn
225 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G11
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 45
Her zaman: 591
