Ana içeriğe geç
Connect Four Electronic Handheld Battery Replacement
Neye ihtiyacın var
  1. Connect Four Electronic Handheld Battery Replacement, Ensure the device is off.: adım 1, 1 resimden 1.
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Battery Replacement, Removing the battery casing.: adım 2, 2 resimden 1. Connect Four Electronic Handheld Battery Replacement, Removing the battery casing.: adım 2, 2 resimden 2.
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Battery Replacement, Replacing the battery.: adım 3, 1 resimden 1.
    • Put in the new AA battery, ensuring that the negative end slides into the spring.
Sonuç
Kamaryn
225 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G11
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 219
