Ana içeriğe geç
Connect Four Electronic Handheld Buttons Replacement
Neye ihtiyacın var
    1. Connect Four Electronic Handheld Buttons Replacement, Ensure the device is off.: adım 1, 1 resimden 1.
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      FixBot'a Sor
      Yorum Ekle
    2. Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: adım 2, 2 resimden 1. Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: adım 2, 2 resimden 2.
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: adım 3, 2 resimden 1. Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: adım 3, 2 resimden 2.
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      FixBot'a Sor
      Yorum Ekle
    1. Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: adım 4, 3 resimden 1. Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: adım 4, 3 resimden 2. Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: adım 4, 3 resimden 3.
      • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
      • Using a spudger, lever the circuit board just enough to where you can easily access the button sheet.
      FixBot'a Sor
      Yorum Ekle
    2. Connect Four Electronic Handheld Buttons Replacement, Removing/ Replacing the Button Sheet: adım 5, 1 resimden 1.
      • Take out the button sheet, and replace it with a new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Julia Wyder
110 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G11
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 708
