Ana içeriğe geç
Connect Four Electronic Handheld Speaker Replacement
Neye ihtiyacın var
  1. Connect Four Electronic Handheld Speaker Replacement, Ensure the device is off.: adım 1, 1 resimden 1.
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
    FixBot'a Sor
    Yorum Ekle
  2. Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: adım 2, 2 resimden 1. Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: adım 2, 2 resimden 2.
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: adım 3, 2 resimden 1. Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: adım 3, 2 resimden 2.
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
    FixBot'a Sor
    Yorum Ekle
  4. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: adım 4, 3 resimden 1. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: adım 4, 3 resimden 2. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: adım 4, 3 resimden 3.
    • If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5.
    • Locate the speaker on the back casing.
    • Using a spudger, wedge the speaker out of its place until it slides out.
    • Take the replacement speaker and wedge it back into its space.
    FixBot'a Sor
    Yorum Ekle
  5. Connect Four Electronic Handheld Speaker Replacement, Re-Soldering the Speaker Wire: adım 5, 1 resimden 1.
    • Using a soldering iron, solder both red wires to their appropriate connections.
    • Be extremely careful when using a soldering iron! Contact with the tip could cause severe burns.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wil
313 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G11
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 593
