Ana içeriğe geç
Connecting the Keypad
  1. Connecting the Keypad, Keypad: adım 1, 2 resimden 1. Connecting the Keypad, Keypad: adım 1, 2 resimden 2.
    • Turn the calculator over so the blue Texas Instruments logo is facing you.
    • Slide the blue cover downwards until it is completely removed from the calculator.
    FixBot'a Sor
    Yorum Ekle
  2. Connecting the Keypad: adım 2, 1 resimden 1.
    • If the keypad is not already connected, skip the next 2 steps.
    • Turn the calculator over so the keypad is facing down.
    • Locate the sliding latch towards the bottom of the calculator.
    FixBot'a Sor
    Yorum Ekle
  3. Connecting the Keypad: adım 3, 2 resimden 1. Connecting the Keypad: adım 3, 2 resimden 2.
    • Slide the latch to the right to release the keypad.
    • At the same time, pull the keypad downwards.
    FixBot'a Sor
    Yorum Ekle
  4. Connecting the Keypad: adım 4, 2 resimden 1. Connecting the Keypad: adım 4, 2 resimden 2.
    • Take note of where the keypad and the calculator connect.
    FixBot'a Sor
    Yorum Ekle
  5. Connecting the Keypad: adım 5, 3 resimden 1. Connecting the Keypad: adım 5, 3 resimden 2. Connecting the Keypad: adım 5, 3 resimden 3.
    • Slide the keypad directly into where it connects to the calculator until you hear a click. Readjust as necessary.
    FixBot'a Sor
    Yorum Ekle
  6. Connecting the Keypad: adım 6, 1 resimden 1.
    • Press the "ON" button to make sure that the calculator turns on. If the calculator turns on correctly, you have properly inserted the keypad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If the keypad was inserted properly, the calculator should turn on without any errors.
Bir başkası bu kılavuzu tamamladı.
Mariel Sanchez
22 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G52
5 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 15,487
