Ana içeriğe geç
Giriş
Capacitors are electronic components found in almost every device containing a circuit board. Large capacitors can store enough charge to cause injuries, so they must be discharged properly.
This guide will show you how to make a simple resistor-based capacitor discharge tool.
  1. To construct a capacitor discharge tool, first gather the necessary materials. These include:
    • To construct a capacitor discharge tool, first gather the necessary materials. These include:
    • Two lengths of wire. Minimum wire requirements is 12AWG, 600 volt rating for large electrolytic capacitors used in power supplies, electric motor start circuits and camera flash circuitry
    • A resistor rated to dissipate the amount of thermal energy created when discharging the capacitor. Minimum requirements for resistor is 2k OHM 5w for small capacitors, 20k OHM 5w for large electrolytic capacitors used in power supplies, electric motor start circuits and camera flash circuitry.
    • Shrink tubing
  2. Begin the process by stripping one side end of each length of wire. To ensure a solid solder joint, strip at least .25" of insulation off the wire.
    • Begin the process by stripping one side end of each length of wire.
    • To ensure a solid solder joint, strip at least .25" of insulation off the wire.
  3. Next, trim both of the leads leaving the resistor to match the length of insulation stripped off the wires in the previous step. Next, trim both of the leads leaving the resistor to match the length of insulation stripped off the wires in the previous step.
    • Next, trim both of the leads leaving the resistor to match the length of insulation stripped off the wires in the previous step.
  4. Join the lead leaving the resistor to the stripped end of the wire by twisting the two together. The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible. Solder the wire to the resistor.
    • Join the lead leaving the resistor to the stripped end of the wire by twisting the two together.
    • The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible.
    • Solder the wire to the resistor.
    • It is essential that enough solder flows through the wire to create a permanent bond between the two pieces.
  5. Slide a section of shrink tubing up the wire, making sure to completely cover up the solder joint and any exposed wire. Use a heat gun or lighter to shrink the tubing over the joint, making sure it is positioned to cover all exposed wire.
    • Slide a section of shrink tubing up the wire, making sure to completely cover up the solder joint and any exposed wire.
    • Use a heat gun or lighter to shrink the tubing over the joint, making sure it is positioned to cover all exposed wire.
  6. Repeat the above process for the other side of the resistor.
    • Repeat the above process for the other side of the resistor.
    • To complete the discharge tool, strip the ends of the wires.
    • To discharge from small points, it may be helpful to cut the exposed ends of wire into a point shape and solder them to maintain the shape. Alternatively, the probes commonly used on multimeters can be soldered to the wires to create a more precise discharge tool.
    • For large electrolytic capacitors used in power supplies, electric motor start circuits, and camera flash units, you may want to solder one end to a large alligator clip and the other to a well insulated screwdriver.
    great idea, thanks
    Edwin Ortiz - Yanıt
Bitiş Çizgisi
111 farklı kişi bu kılavuzu tamamladı.
8 Yorum
thank you !!! :)
Sufian Hamouda - Yanıt
This article is by far the best I've read. I have made these in the past and had to get past the amount of words used to describe what needed to be done with what. This article is straight to the point and the tips ( using alligator clip ) are excellent.
Paul Kriner - Yanıt
I get the basics and can build something more to fit my needs, with what you have instructed
puckhead22 - Yanıt
hi
i have one query, if it is possible to discharge the capacitor in 12V 1 A power supply..? if i cut of the power, the power supply discharge the power around 6 sec but i need to discharge it with in 1 sec ..? this is possible or Not...?
prakashkumar - Yanıt
Thank you! I have been looking for a good diy discharge probe....I also used overlapping large size heat shrink to strengthen the joint at the ceramic resistor to prevent failure at a bad time.
doorabull2 - Yanıt
Great. Now how do I use it?!?!
Rex Kramer - Yanıt
i believe all you need to do is by bridging every lead with your built capacitor discharge. I could be wrong tho
Hendry Ramadhan -
just want to say thank you for great explanation! Terima kasih, from Indonesia
Hendry Ramadhan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 200
Son 30 gün: 987
Her zaman: 167,187
