Ana içeriğe geç
Contour Roam2 Back Door Replacement
Neye ihtiyacın var
    1. Contour Roam2 Back Door Replacement, Record Slider: adım 1, 1 resimden 1.
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      FixBot'a Sor
      Yorum Ekle
    2. Contour Roam2 Back Door Replacement: adım 2, 2 resimden 1. Contour Roam2 Back Door Replacement: adım 2, 2 resimden 2.
      • Rotate the metal ring counterclockwise until completely removed.
      FixBot'a Sor
      Yorum Ekle
    3. Contour Roam2 Back Door Replacement: adım 3, 2 resimden 1. Contour Roam2 Back Door Replacement: adım 3, 2 resimden 2.
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Contour Roam2 Back Door Replacement: adım 4, 3 resimden 1. Contour Roam2 Back Door Replacement: adım 4, 3 resimden 2. Contour Roam2 Back Door Replacement: adım 4, 3 resimden 3.
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      FixBot'a Sor
      Yorum Ekle
    5. Contour Roam2 Back Door Replacement: adım 5, 1 resimden 1.
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      FixBot'a Sor
      Yorum Ekle
    1. Contour Roam2 Back Door Replacement, Mounting Piece: adım 6, 2 resimden 1. Contour Roam2 Back Door Replacement, Mounting Piece: adım 6, 2 resimden 2.
      • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
      FixBot'a Sor
      Yorum Ekle
    2. Contour Roam2 Back Door Replacement: adım 7, 2 resimden 1. Contour Roam2 Back Door Replacement: adım 7, 2 resimden 2.
      • Open the back door by your thumb and index finger on sides of back door and pull upward.
      FixBot'a Sor
      Yorum Ekle
    3. Contour Roam2 Back Door Replacement: adım 8, 1 resimden 1.
      • Using your thumb, pry sides outward on back of mount piece.
      • This will loosen mount piece for removal in proceeding step.
      • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
      FixBot'a Sor
      Yorum Ekle
    4. Contour Roam2 Back Door Replacement: adım 9, 2 resimden 1. Contour Roam2 Back Door Replacement: adım 9, 2 resimden 2.
      • Remove and replace mount piece.
      FixBot'a Sor
      Yorum Ekle
    1. Contour Roam2 Back Door Replacement, Back Door: adım 10, 1 resimden 1.
      • Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
      • After removing the metal bar, the spring will become loose and may fall out on its own.
      FixBot'a Sor
      Yorum Ekle
    2. Contour Roam2 Back Door Replacement: adım 11, 1 resimden 1.
      • Remove and replace back door.
      • Door should easily be removed by pulling away from main body of camera.
      • As door is being pulled away, the spring may fall out own its own.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jamie Maple
310 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-5, Panko Spring 2015 Colorado Springs, Team 4-5, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G5
3 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
Where can I get a replacement back door for an original contour roam shipped international? Contour will not reapond to my requests.
The Dude - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 35
Her zaman: 2,223
