Ana içeriğe geç
Contour Roam2 Mounting Piece Replacement
Neye ihtiyacın var
  1. Contour Roam2 Mounting Piece Replacement, Record Slider: adım 1, 1 resimden 1.
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Mounting Piece Replacement: adım 2, 2 resimden 1. Contour Roam2 Mounting Piece Replacement: adım 2, 2 resimden 2.
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Mounting Piece Replacement: adım 3, 2 resimden 1. Contour Roam2 Mounting Piece Replacement: adım 3, 2 resimden 2.
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Mounting Piece Replacement: adım 4, 3 resimden 1. Contour Roam2 Mounting Piece Replacement: adım 4, 3 resimden 2. Contour Roam2 Mounting Piece Replacement: adım 4, 3 resimden 3.
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Mounting Piece Replacement: adım 5, 1 resimden 1.
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
  6. Contour Roam2 Mounting Piece Replacement, Mounting Piece: adım 6, 2 resimden 1. Contour Roam2 Mounting Piece Replacement, Mounting Piece: adım 6, 2 resimden 2.
    • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
  7. Contour Roam2 Mounting Piece Replacement: adım 7, 2 resimden 1. Contour Roam2 Mounting Piece Replacement: adım 7, 2 resimden 2.
    • Open the back door by your thumb and index finger on sides of back door and pull upward.
  8. Contour Roam2 Mounting Piece Replacement: adım 8, 1 resimden 1.
    • Using your thumb, pry sides outward on back of mount piece.
    • This will loosen mount piece for removal in proceeding step.
    • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
  9. Contour Roam2 Mounting Piece Replacement: adım 9, 2 resimden 1. Contour Roam2 Mounting Piece Replacement: adım 9, 2 resimden 2.
    • Remove and replace mount piece.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Matthew Kofsky
548 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-5, Panko Spring 2015 Colorado Springs, Team 4-5, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G5
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Hi i need this part...
julmarte - Yanıt
I Need a battery, and check up.
Too many small screws for me, I am using it on a home defense air powered 50 cal with orange top. need to have a mount for that Ball Shooter. where can I get that project I live in the 831 AC
Or is their something used already working I got this needing a battery.
Help from a Person I can mail it
Thanks Dudley
Dudley Walsh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,466
