Giriş
This guide will give you step-by-step instructions on how to replace the record slider on your Contour Roam2 waterproof action camera if the camera won't begin or end recording properly.
Neye ihtiyacın var
Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
