Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
These procedures will instruct the reader how to remove and replace the camera.
  1. After removing the back of the phone (not pictured), remove the battery by lifting up from the bottom with your thumb. There will be a groove that allows you to remove the battery with your thumb.
    • After removing the back of the phone (not pictured), remove the battery by lifting up from the bottom with your thumb. There will be a groove that allows you to remove the battery with your thumb.
  2. Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner. Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner. Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner.
    • Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner.
  3. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together. Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together. Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together.
    • Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together.
  5. After the clips are released, carefully separate the back housing from the phone. Notice the sticker that appears in the red box holds the phone together, but can be peeled apart.
    • After the clips are released, carefully separate the back housing from the phone. Notice the sticker that appears in the red box holds the phone together, but can be peeled apart.
  6. Carefully use the nylon spudger to pry the camera from its connector. Carefully use the nylon spudger to pry the camera from its connector.
    • Carefully use the nylon spudger to pry the camera from its connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cordell Miller
273 İtibar
2 adet Kılavuz yazıldı
Takım
IUPUI, Team S1-G3, Harley Spring 2018 IUPUI, Team S1-G3, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G3
6 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 157
