Ana içeriğe geç
Coolpad 3300A Screen Replacement
Neye ihtiyacın var
  1. Coolpad 3300A Screen Replacement, Coolpad 3300A Disassembly: adım 1, 1 resimden 1.
    • After removing the back of the phone (not pictured), remove the battery by lifting up from the bottom with your thumb. There will be a groove that allows you to remove the battery with your thumb.
  2. Coolpad 3300A Screen Replacement: adım 2, 3 resimden 1. Coolpad 3300A Screen Replacement: adım 2, 3 resimden 2. Coolpad 3300A Screen Replacement: adım 2, 3 resimden 3.
    • Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner.
  3. Coolpad 3300A Screen Replacement: adım 3, 3 resimden 1. Coolpad 3300A Screen Replacement: adım 3, 3 resimden 2. Coolpad 3300A Screen Replacement: adım 3, 3 resimden 3.
    • Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together.
  4. Coolpad 3300A Screen Replacement: adım 4, 1 resimden 1.
    • After the clips are released, carefully separate the back housing from the phone. Notice the sticker that appears in the red box holds the phone together, but can be peeled apart.
  5. Coolpad 3300A Screen Replacement, Screen: adım 5, 2 resimden 1. Coolpad 3300A Screen Replacement, Screen: adım 5, 2 resimden 2.
    • Remove the ribbon cable by flipping up the connector.
  6. Coolpad 3300A Screen Replacement: adım 6, 1 resimden 1.
    • Remove second ribbon cable shown in red box. To do this repeat step 5.
  7. Coolpad 3300A Screen Replacement: adım 7, 3 resimden 1. Coolpad 3300A Screen Replacement: adım 7, 3 resimden 2. Coolpad 3300A Screen Replacement: adım 7, 3 resimden 3.
    • Use the nylon spudger to gently pry/release clips to remove motherboard from the screen.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Cordell Miller
318 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Harley Spring 2018 IUPUI, Team S1-G3, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G3
6 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
How do I replace the screen? You just told me how to take it apart.
Computer User - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 2,194
