Ana içeriğe geç
Coolpad Defiant Battery Replacement
Neye ihtiyacın var
  1. Coolpad Defiant Battery Replacement, Back Cover: adım 1, 2 resimden 1. Coolpad Defiant Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Battery Replacement: adım 2, 1 resimden 1.
    • Remove the back cover from your device.
  3. Coolpad Defiant Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 1,450
