Ana içeriğe geç
Coolpad Defiant Daughterboard Replacement
Neye ihtiyacın var
  1. Coolpad Defiant Daughterboard Replacement, Back Cover: adım 1, 2 resimden 1. Coolpad Defiant Daughterboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Daughterboard Replacement: adım 2, 1 resimden 1.
    • Remove the back cover from your device.
  3. Coolpad Defiant Daughterboard Replacement, Battery: adım 3, 1 resimden 1.
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Daughterboard Replacement, Daughterboard: adım 4, 2 resimden 1. Coolpad Defiant Daughterboard Replacement, Daughterboard: adım 4, 2 resimden 2.
    • Remove all fifteen screws using the Phillips #000 screwdriver.
    • Remove the back panel after all screws are removed.
  5. Coolpad Defiant Daughterboard Replacement: adım 5, 3 resimden 1. Coolpad Defiant Daughterboard Replacement: adım 5, 3 resimden 2. Coolpad Defiant Daughterboard Replacement: adım 5, 3 resimden 3.
    • Disconnect the metal cable using the plastic spudger.
    • The remove the glued down speaker from the backing.
    • Disconnect the little black wire from lower logic board.
  6. Coolpad Defiant Daughterboard Replacement: adım 6, 1 resimden 1.
    • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
Sonuç
Elijah Gastin
100 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 10
Her zaman: 460
