Giriş
Broken screen, cracked screen, no screen? No problem! If you own a Nikon Coolpix digital camera and are experiencing a screen cover problem, this guide will surely help.
Neye ihtiyacın var
First make sure the camera is powered off.
Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
Next, remove the 2 mm screw from the right side of the camera
Remove the 3mm screw from the bottom of the camera.
Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
Be sure to remove the battery before continuing your repair.
Bir başkası bu kılavuzu tamamladı.
