Ana içeriğe geç
Coolpix S01 Screen Cover Replacement
Neye ihtiyacın var
  1. Coolpix S01 Screen Cover Replacement, Screen Cover: adım 1, 3 resimden 1. Coolpix S01 Screen Cover Replacement, Screen Cover: adım 1, 3 resimden 2. Coolpix S01 Screen Cover Replacement, Screen Cover: adım 1, 3 resimden 3.
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
  2. Coolpix S01 Screen Cover Replacement: adım 2, 3 resimden 1. Coolpix S01 Screen Cover Replacement: adım 2, 3 resimden 2. Coolpix S01 Screen Cover Replacement: adım 2, 3 resimden 3.
    • Next, remove the 2 mm screw from the right side of the camera
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Screen Cover Replacement: adım 3, 3 resimden 1. Coolpix S01 Screen Cover Replacement: adım 3, 3 resimden 2. Coolpix S01 Screen Cover Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With the screen facing outward, locate the orange ribbon cable from the motherboard.
    • With the straight tweezers, gently pull out the orange ribbon cable from the motherboard.
  4. Coolpix S01 Screen Cover Replacement: adım 4, 3 resimden 1. Coolpix S01 Screen Cover Replacement: adım 4, 3 resimden 2. Coolpix S01 Screen Cover Replacement: adım 4, 3 resimden 3.
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen.
    • Use the plastic tool to gently lift the screen out from the upper left corner until the seal is broken.
Sonuç
Bir başkası bu kılavuzu tamamladı.
angelica fitzgerald
216 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 556
