Ana içeriğe geç
Coolpix S01 USB Cover Replacement
Neye ihtiyacın var
  1. Coolpix S01 USB Cover Replacement, USB Cover: adım 1, 3 resimden 1. Coolpix S01 USB Cover Replacement, USB Cover: adım 1, 3 resimden 2. Coolpix S01 USB Cover Replacement, USB Cover: adım 1, 3 resimden 3.
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
    • Next remove the 2 mm screw from the right side of the camera.
  2. Coolpix S01 USB Cover Replacement: adım 2, 3 resimden 1. Coolpix S01 USB Cover Replacement: adım 2, 3 resimden 2. Coolpix S01 USB Cover Replacement: adım 2, 3 resimden 3.
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 USB Cover Replacement: adım 3, 3 resimden 1. Coolpix S01 USB Cover Replacement: adım 3, 3 resimden 2. Coolpix S01 USB Cover Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • On the bottom of the camera, locate the USB port.
    • Gently slide the USB cover off of the camera with your fingers or tweezers.
    • You can replace the USB cover by purchasing one from a local electronics store or online at iFixit.com.
Sonuç
Fernando Ochoa
113 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 398
