Ana içeriğe geç
Coolpix S01 Zoom Trigger Replacement
Neye ihtiyacın var
  1. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: adım 1, 3 resimden 1. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: adım 1, 3 resimden 2. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: adım 1, 3 resimden 3.
    • Before starting, make sure the camera is powered off.
    • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
    • Next, remove the 2mm screw from the right side.
    • Lastly, remove the 3mm screw from the bottom of the camera.
  2. Coolpix S01 Zoom Trigger Replacement: adım 2, 3 resimden 1. Coolpix S01 Zoom Trigger Replacement: adım 2, 3 resimden 2. Coolpix S01 Zoom Trigger Replacement: adım 2, 3 resimden 3.
    • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Zoom Trigger Replacement: adım 3, 2 resimden 1. Coolpix S01 Zoom Trigger Replacement: adım 3, 2 resimden 2.
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. With the Hex and the J000 bit remove the two 1mm screws.
  4. Coolpix S01 Zoom Trigger Replacement: adım 4, 2 resimden 1. Coolpix S01 Zoom Trigger Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Take the needle nose tweezers to remove the black ring in the middle of the button.
    • You have successfully removed the zoom trigger and can replace with a new one if needed.
    • To reassemble follow steps in reverse.
Sonuç
angelica fitzgerald
216 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 324
