Ana içeriğe geç
Core Assembly Removal
Neye ihtiyacın var
  1. Core Assembly Removal, Opening Procedure: adım 1, 1 resimden 1.
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
    FixBot'a Sor
    Yorum Ekle
  2. Core Assembly Removal: adım 2, 2 resimden 1. Core Assembly Removal: adım 2, 2 resimden 2.
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
    FixBot'a Sor
    Yorum Ekle
  3. Core Assembly Removal: adım 3, 2 resimden 1. Core Assembly Removal: adım 3, 2 resimden 2.
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Core Assembly Removal: adım 4, 2 resimden 1. Core Assembly Removal: adım 4, 2 resimden 2.
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Core Assembly Removal: adım 5, 3 resimden 1. Core Assembly Removal: adım 5, 3 resimden 2. Core Assembly Removal: adım 5, 3 resimden 3.
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
    FixBot'a Sor
    Yorum Ekle
  6. Core Assembly Removal, Core Assembly Removal: adım 6, 2 resimden 1. Core Assembly Removal, Core Assembly Removal: adım 6, 2 resimden 2.
    • Use a spudger to disconnect the display flex cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Core Assembly Removal: adım 7, 2 resimden 1. Core Assembly Removal: adım 7, 2 resimden 2.
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
134.397 İtibar
189 adet Kılavuz yazıldı
Ekip
3Kılavuz Yorumları
thanks, loved seeing this watch from the inside!
Crystal Blu - Yanıt Paylaş
Great, but now I need to know how to get to the glass to replace it.
selwood.maria - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 51
Her zaman: 4,351
