Ana içeriğe geç
Core Assembly Removal
Neye ihtiyacın var
  1. Core Assembly Removal, Unfasten the screws: adım 1, 1 resimden 1.
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
    FixBot'a Sor
    Yorum Ekle
  2. Core Assembly Removal, Open the watch: adım 2, 2 resimden 1. Core Assembly Removal, Open the watch: adım 2, 2 resimden 2.
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
    FixBot'a Sor
    Yorum Ekle
  3. Core Assembly Removal, Disconnect the sensor cable: adım 3, 2 resimden 1. Core Assembly Removal, Disconnect the sensor cable: adım 3, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
    FixBot'a Sor
    Yorum Ekle
  4. Core Assembly Removal, Remove the back cover: adım 4, 1 resimden 1.
    • Remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  5. Core Assembly Removal, Core Assembly Removal: adım 5, 1 resimden 1.
    • Remove the three 3.7 mm-long Phillips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  6. Core Assembly Removal: adım 6, 3 resimden 1. Core Assembly Removal: adım 6, 3 resimden 2. Core Assembly Removal: adım 6, 3 resimden 3.
    • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
    • Use your spudger as a lever and pry up the core assembly.
    • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
    FixBot'a Sor
    Yorum Ekle
  7. Core Assembly Removal: adım 7, 2 resimden 1. Core Assembly Removal: adım 7, 2 resimden 2.
    • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
    • Be careful not to strain the display and sensor flex cables during this procedure.
    FixBot'a Sor
    Yorum Ekle
  8. Core Assembly Removal: adım 8, 2 resimden 1. Core Assembly Removal: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
    FixBot'a Sor
    Yorum Ekle
  9. Core Assembly Removal: adım 9, 2 resimden 1. Core Assembly Removal: adım 9, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
    FixBot'a Sor
    Yorum Ekle
  10. Core Assembly Removal: adım 10, 1 resimden 1.
    • Remove the core assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Check out our Answers community for help.
4 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
261.483 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.531 adet Kılavuz yazıldı
1Rehber Yorum
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
luciano.alonso84@gmail.com - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,655
