Ana içeriğe geç
Core Assembly Removal
Neye ihtiyacın var
    1. Core Assembly Removal, Unfasten the back cover screws: adım 1, 1 resimden 1.
      • Before starting repairs, take your watch off the charger and power it down.
      • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
      • Don’t worry about removing the screws, they will stay in place in the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. Core Assembly Removal, Wedge open the back cover: adım 2, 2 resimden 1. Core Assembly Removal, Wedge open the back cover: adım 2, 2 resimden 2.
      • Insert an opening tool between the back cover and the metal housing.
      • Twist the opening tool to create a wider gap.
      • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Core Assembly Removal, Disconnect the sensor flex cable: adım 3, 3 resimden 1. Core Assembly Removal, Disconnect the sensor flex cable: adım 3, 3 resimden 2. Core Assembly Removal, Disconnect the sensor flex cable: adım 3, 3 resimden 3.
      • Lay the watch face down.
      • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Core Assembly Removal, Remove the back cover: adım 4, 2 resimden 1. Core Assembly Removal, Remove the back cover: adım 4, 2 resimden 2.
      • Remove the back cover.
      • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
      FixBot'a Sor
      Yorum Ekle
    1. Core Assembly Removal, Unplug the display connector: adım 5, 2 resimden 1. Core Assembly Removal, Unplug the display connector: adım 5, 2 resimden 2.
      • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Core Assembly Removal, Loosen the core assembly: adım 6, 2 resimden 1. Core Assembly Removal, Loosen the core assembly: adım 6, 2 resimden 2.
      • The core's plastic frame fits tightly within the watch's metal housing.
      • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
      • Twist and tilt the spudger to lever the core assembly out of the metal housing.
      FixBot'a Sor
      Yorum Ekle
    3. Core Assembly Removal, Remove the core assembly: adım 7, 3 resimden 1. Core Assembly Removal, Remove the core assembly: adım 7, 3 resimden 2. Core Assembly Removal, Remove the core assembly: adım 7, 3 resimden 3.
      • Carefully thread the display flex cable through the gap on the core's plastic frame.
      • Remove the core assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Tobias Isakeit
134.915 İtibar
189 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 62
Her zaman: 1,695
