Ana içeriğe geç
Core Assembly Removal
Neye ihtiyacın var
  1. Core Assembly Removal, Turn off the watch: adım 1, 2 resimden 1. Core Assembly Removal, Turn off the watch: adım 1, 2 resimden 2.
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Core Assembly Removal, Remove the rear screws: adım 2, 1 resimden 1.
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Core Assembly Removal, Separate the back cover from the housing: adım 3, 3 resimden 1. Core Assembly Removal, Separate the back cover from the housing: adım 3, 3 resimden 2. Core Assembly Removal, Separate the back cover from the housing: adım 3, 3 resimden 3.
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Core Assembly Removal, Disconnect the sensor array: adım 4, 2 resimden 1. Core Assembly Removal, Disconnect the sensor array: adım 4, 2 resimden 2.
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Core Assembly Removal, Remove the back cover: adım 5, 1 resimden 1.
    • Remove the back cover.
  6. Core Assembly Removal, Disconnect the display and the mic array: adım 6, 3 resimden 1. Core Assembly Removal, Disconnect the display and the mic array: adım 6, 3 resimden 2. Core Assembly Removal, Disconnect the display and the mic array: adım 6, 3 resimden 3.
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
  7. Core Assembly Removal, Undo the mic tape: adım 7, 3 resimden 1. Core Assembly Removal, Undo the mic tape: adım 7, 3 resimden 2. Core Assembly Removal, Undo the mic tape: adım 7, 3 resimden 3.
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
  8. Core Assembly Removal, Lift the core assembly: adım 8, 2 resimden 1. Core Assembly Removal, Lift the core assembly: adım 8, 2 resimden 2.
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
  9. Core Assembly Removal, Remove the core assembly: adım 9, 3 resimden 1. Core Assembly Removal, Remove the core assembly: adım 9, 3 resimden 2. Core Assembly Removal, Remove the core assembly: adım 9, 3 resimden 3.
    • Lift out and remove the core assembly.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
129.685 İtibar
189 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,833
