Ana içeriğe geç
Corsair Katar DPI Sensor Replacement
Neye ihtiyacın var
  1. Corsair Katar DPI Sensor Replacement, Corsair Katar Disassembly: adım 1, 2 resimden 1. Corsair Katar DPI Sensor Replacement, Corsair Katar Disassembly: adım 1, 2 resimden 2.
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar DPI Sensor Replacement: adım 2, 1 resimden 1.
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar DPI Sensor Replacement: adım 3, 2 resimden 1. Corsair Katar DPI Sensor Replacement: adım 3, 2 resimden 2.
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar DPI Sensor Replacement: adım 4, 1 resimden 1.
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar DPI Sensor Replacement, DPI Sensor: adım 5, 2 resimden 1. Corsair Katar DPI Sensor Replacement, DPI Sensor: adım 5, 2 resimden 2.
    • Use the JIS 0 screwdriver to remove the two 5mm screws holding the DPI sensor.
  6. Corsair Katar DPI Sensor Replacement: adım 6, 1 resimden 1.
    • Lift the DPI sensor away from the mouse shell.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Margaret Loughren
594 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G3, Cardinal Summer 2018 UW Tacoma, Team S1-G3, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 411
