Ana içeriğe geç
Corsair Scimitar Mouse Wheel Replacement
Neye ihtiyacın var
  1. Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: adım 1, 2 resimden 1. Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: adım 1, 2 resimden 2.
    • Heat the mouse feet with a heat gun to loosen the adhesive.
    • Pry the mouse feet off of the mouse with the metal spudger.
  2. Corsair Scimitar Mouse Wheel Replacement: adım 2, 2 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 2, 2 resimden 2.
    • Unscrew the four 8.9 mm bottom screws with a JIS #00 screwdriver.
    • Loosen the keyslider lock with a 2.5 mm hex screw driver.
  3. Corsair Scimitar Mouse Wheel Replacement: adım 3, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 3, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 3, 3 resimden 3.
    • Pry along the seam of the mouse body to separate the top and bottom halves.
  4. Corsair Scimitar Mouse Wheel Replacement: adım 4, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 4, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 4, 3 resimden 3.
    • Remove the top cover from the mouse.
  5. Corsair Scimitar Mouse Wheel Replacement: adım 5, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 5, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 5, 3 resimden 3.
    • Lift the locking mechanism on the auxiliary switch board ribbon cable connector with a plastic spudger.
    • Pull the ribbon cable gently to disconnect from the main board.
  6. Corsair Scimitar Mouse Wheel Replacement: adım 6, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 6, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 6, 3 resimden 3.
    • Lift the locking mechanism on the Key Slider assembly ribbon cable connector with a plastic spudger.
    • Pull the Key Slider assembly ribbon cable gently to disconnect it from the main board.
  7. Corsair Scimitar Mouse Wheel Replacement: adım 7, 2 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 7, 2 resimden 2.
    • Pull the Keyslider ribbon cable up and out of the plastic post.
  8. Corsair Scimitar Mouse Wheel Replacement: adım 8, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 8, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 8, 3 resimden 3.
    • Use a JIS #0 screwdriver to remove the 6 mm screw from the key slider assembly.
    • Remove the key slider assembly from the body of the mouse.
  9. Corsair Scimitar Mouse Wheel Replacement: adım 9, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 9, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 9, 3 resimden 3.
    • Disconnect the data cable from the auxiliary switch board.
  10. Corsair Scimitar Mouse Wheel Replacement: adım 10, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 10, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 10, 3 resimden 3.
    • Use a JIS #0 screwdriver to remove the two 6 mm screws from the auxiliary switch board.
    • Remove the auxiliary switch board.
  11. Corsair Scimitar Mouse Wheel Replacement: adım 11, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 11, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 11, 3 resimden 3.
    • Use a JIS #0 screwdriver to remove the three 6 mm screws from the main board to separate it from the mouse body.
  12. Corsair Scimitar Mouse Wheel Replacement: adım 12, 2 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 12, 2 resimden 2.
    • Disconnect the data cable from the main board.
  13. Corsair Scimitar Mouse Wheel Replacement: adım 13, 2 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 13, 2 resimden 2.
    • Lift the main board off of the body of the mouse.
  14. Corsair Scimitar Mouse Wheel Replacement: adım 14, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 14, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 14, 3 resimden 3.
    • Push the scroll wheel gently away from the rotary encoder switch to remove it.
    • Check the rotary encoder hex hole to make sure it is clear of debris.
  15. Corsair Scimitar Mouse Wheel Replacement: adım 15, 3 resimden 1. Corsair Scimitar Mouse Wheel Replacement: adım 15, 3 resimden 2. Corsair Scimitar Mouse Wheel Replacement: adım 15, 3 resimden 3.
    • Remove the rubber ring from the scroll wheel.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 50
Son 30 gün: 277
Her zaman: 7,377
