Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Cut two pieces of foam for each seat cushion.
Bottom seat: 14" x 12"
Back rest: 14" x 6"
Cut two pieces of oil cloth for each seat.
Bottom seat: 20" x 18"
Back rest: 17.5" x 9.5"
Using a Phillips #0 screwdriver, unscrew the back rest from the stool.
To detach the seat, lift up the seat and use a flathead screwdriver to lift up all four tabs underneath.
Use the flathead screwdriver to pry the top of the seat off.
Use a flathead screwdriver to lift up the tabs on the back rest to remove the metal plate.
Use the spray adhesive to spray the metal plates and apply the foam to their respective pieces.
Let it sit for five minutes to dry.
Spray adhesive onto foam and center each metal plate on the cloth so that there is an equal amount of cloth peeking out on all four sides.
Smooth cloth onto each metal plate, pushing from the center, outwards.
Fold the cloth up over the sides and clothespin it down along all four edges.
Let it dry for at least one hour.
7 farklı kişi bu kılavuzu tamamladı.
