Ana içeriğe geç
Cosori Pro II Shell Replacement
Neye ihtiyacın var
  1. Cosori Pro II Shell Replacement, Shell: adım 1, 1 resimden 1.
    • Flip the device upside down and remove all of the Phillips #1 screws.
    FixBot'a Sor
    Yorum Ekle
  2. Cosori Pro II Shell Replacement: adım 2, 2 resimden 1. Cosori Pro II Shell Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
    • Remove the panel.
    FixBot'a Sor
    Yorum Ekle
  3. Cosori Pro II Shell Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove all four screws.
    • Lift off the bracket.
    • When lifting this off be careful to not unplug the screen.
    FixBot'a Sor
    Yorum Ekle
  4. Cosori Pro II Shell Replacement: adım 4, 2 resimden 1. Cosori Pro II Shell Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
    • Dissemble the shell going up to separate the basket holder.
    FixBot'a Sor
    Yorum Ekle
  5. Cosori Pro II Shell Replacement: adım 5, 2 resimden 1. Cosori Pro II Shell Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
    • Be careful to not apply too much force to the metal as it can cause it to warp it, and so it is easy rescrew the plastic piece in place.
    FixBot'a Sor
    Yorum Ekle
  6. Cosori Pro II Shell Replacement: adım 6, 2 resimden 1. Cosori Pro II Shell Replacement: adım 6, 2 resimden 2.
    • Pull the bottom shell down pulling at the sides to get them over screw holes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Matthewmm
335 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 805
