Ana içeriğe geç
Cowin E7 Ear Cushion Replacement
Neye ihtiyacın var
  1. Cowin E7 Ear Cushion Replacement, Ear Cushion: adım 1, 1 resimden 1.
    • Inspect the seal around the edge of each ear cushion for damage or instability.
    • Make note of which ear cushion needs to be replaced.
  2. Cowin E7 Ear Cushion Replacement: adım 2, 1 resimden 1.
    • Firmly grasp the ear cushion on one side and pull up.
    • The ear cushion is only attached by a few spots of glue, so it should not take much force to remove.
  3. Cowin E7 Ear Cushion Replacement: adım 3, 1 resimden 1.
    • Spread multipurpose glue around the edge of the seal.
    • Keep in mind that the more glue you use, the harder it will be to remove the ear cushions again.
    • Place the replacement ear cushions where the damaged cushions were.
    • Hold for at least thirty seconds to ensure the glue has time to dry and seal the new cushions to the headphones.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Jacob Burrer
439 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Mellen Spring 2022 UMass Dartmouth, Team 2-2, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S2G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 43
Son 30 gün: 202
Her zaman: 4,841
