Ana içeriğe geç
Craftsman Model 315.10721 Blade Replacement
Neye ihtiyacın var
  1. Craftsman Model 315.10721 Blade Replacement, Blade: adım 1, 1 resimden 1.
    • Be sure to unplug the saw before proceeding.
    • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
    • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
    • It is not necessary to completely remove the screws.
  2. Craftsman Model 315.10721 Blade Replacement: adım 2, 1 resimden 1.
    • Carefully take the replacement blade and insert it into the saw blade clamp.
    • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
Bitiş Çizgisi
Riley Hilliker
557 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-47, Amido Fall 2014 Cal Poly, Team 4-47, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G47
4 Üyeler
2 Yorum
Where can I get replacement blades for this saw.
Edward - Yanıt
Where can I get replacement blades for this saw?
Edward - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 59
Her zaman: 3,367
