Ana içeriğe geç
Craftsman Model 315.10721 Brush Replacement
Neye ihtiyacın var
  1. Craftsman Model 315.10721 Brush Replacement, Brush: adım 1, 2 resimden 1. Craftsman Model 315.10721 Brush Replacement, Brush: adım 1, 2 resimden 2.
    • Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
  2. Craftsman Model 315.10721 Brush Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
    • The washer is seurely held in place and may require force to remove
  3. Craftsman Model 315.10721 Brush Replacement: adım 3, 1 resimden 1.
    • After the washers are removed, gently grab the old brushes and remove them from the motor.
    • When reassembling make sure the curvature of the brushes match curvature of the motor.
Sonuç
Riley Hilliker
557 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-47, Amido Fall 2014 Cal Poly, Team 4-47, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G47
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 1,445
