Ana içeriğe geç
Craftsman Model 315.10721 Cord Replacement
Neye ihtiyacın var
  1. Craftsman Model 315.10721 Cord Replacement, Cord: adım 1, 1 resimden 1.
    • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
    • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
    • Once the five screws are removed, lift the handle cover from the saw.
    • Each screw has a corresponding nut on the opposite side of the power saw
  2. Craftsman Model 315.10721 Cord Replacement: adım 2, 1 resimden 1.
    • Remove the 1/2" Phillips screw that is securing the switch using a Phillips #1 screwdriver.
  3. Craftsman Model 315.10721 Cord Replacement: adım 3, 2 resimden 1. Craftsman Model 315.10721 Cord Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the power cord are plugged in.
    • Release both the black and white wires and gently pull them from the leads.
    • To install the new cord, insert the wires of the new cord in the same way that they were removed.
Sonuç
Riley Hilliker
557 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-47, Amido Fall 2014 Cal Poly, Team 4-47, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G47
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 512
