Ana içeriğe geç
Craig CMP801 Battery Replacement
Neye ihtiyacın var
  1. Craig CMP801 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Craig CMP801 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: adım 2, 2 resimden 1. Craig CMP801 Battery Replacement: adım 2, 2 resimden 2.
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: adım 3, 2 resimden 1. Craig CMP801 Battery Replacement: adım 3, 2 resimden 2.
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: adım 4, 3 resimden 1. Craig CMP801 Battery Replacement, Battery: adım 4, 3 resimden 2. Craig CMP801 Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: adım 5, 3 resimden 1. Craig CMP801 Battery Replacement: adım 5, 3 resimden 2. Craig CMP801 Battery Replacement: adım 5, 3 resimden 3.
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Duyen
281 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Where do I find a battery cmp749 ???
kourriclay929 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 1,007
