Giriş
This guide will walk you through the process of replacing the broken front or rear facing camera of a Craig CMP801.
Neye ihtiyacın var
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
Bir başkası bu kılavuzu tamamladı.
