Giriş
In order to replace the LCD screen you must remove all the other parts, starting from the back panel.
Neye ihtiyacın var
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
After taking out the back cover, locate the black flap.
Open the black flap with the plastic opening tools.
Bu adımda kullanılan alet:Tweezers$3.99
Once the tab is released, use the angled tweezers to take out the tab.
Locate the white plug next to the battery.
Use your fingers to pull off white plug that connected to the battery.
Bir başkası bu kılavuzu tamamladı.
